Filter a Schedule using a logic "OR" instead of "AND"
IAN~JAMES
Message 1 of 55
IAN~JAMES
Is there any way of building a schedule that is filtered using a logic "OR" instead of "AND"
We want to schedule out Rooms that satisfy a limited range of parameter values initially just two will do, but it begs the question whether it is possible to filter using a list of acceptable values such as
...Where Parameter.Value IN(ValueA, ValueB, ValueC, ValueD...)
I seem to remember this from SQL many moons ago!
Any suggestions appreciated.
Cheers
Replies (54)
Message 2 of 55
I find the "Does not Contain" option useful when I really would like to use "Or".  You may need to think about your selection criteria a bit more carefully , but I have found this always works for me.
Message 3 of 55
This doesn't work if you want to filter for example 5 categories from 30.
Message 4 of 55
MostafaElashmawy
Please check attached trick from a comment at
http://revitcat.blogspot.com
I think this idea is brilliant.
Mostafa Elashmawy
Message 5 of 55
Now is that better than a Yes/No checkbox?
Message 6 of 55
loboarch
OR filters are currently being worked on.  Check the Revit Roadmap.
http://blogs.autodesk.com/revit/2017/08/31/revit-roadmap-update-august-2017/
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 7 of 55
Sahay_R
Try Combined Parameters. You can set the field to pull as many or as few parameters as you need.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 8 of 55
HE-MJJ
It's 2018. I would like to filter out three categories.
Message 9 of 55
loboarch
You can make a filter that looks at 3 categories. You have been able to do that for a long time. Probably since back in 2011 or before when this thread started. Here is a filter that looks for "Furniture", "Lighting Fixtures", and "Windows" all on "Level 1 Living Rm."
This thread is about being able to include OR operators in the filter. Which is now possible in the 2019 release of Revit. Here is an example of a filter, still looking at the same 3 categories but now will find elements on level "Level 1-Living Rm." OR elements who's Type Mark is greater than "46".
You can nest and combine AND and OR operators in the filter and also filter for more than 4 parameters (which was the previous limit).
Maybe this gives you the functionality you need?
Jeff Hanson
Revit Help |
Message 10 of 55
HE-MJJ
I was looking for an "or" here; https://www.screencast.com/t/uJGkZou33s
Message 11 of 55
Alfredo_Medina
@loboarch wrote:
@loboarch Jeff, I think there is a confusion. This thread is about using the OR operator in the filter tab of a schedule, which is still not possible in Revit 2019.
Message 12 of 55
loboarch
I see. Yes the OR filter was only implemented for VIEW filters not schedule filters. Sorry about the confusion.
Jeff Hanson
Revit Help |
Message 13 of 55
HE-MJJ
Yes, I understand. Thanks. Sorry for the confusion.
Message 14 of 55
TimothyBesser
Autodesk is behind the times. This should have been done a long time ago, along with using multiple cores. I guess this is what happens when Autodesk takes other programs with out understanding them and try to apply them to their business model with out correctly fixing your programs according to user complaints.
Sorry for the rant.
Is this issue on track to being resolved; Do we have Autodesk support on this?
Message 15 of 55
SzyKo
"Do we have Autodesk support on this? "
Ahahahahaha, good one :D:D:D...
Message 16 of 55
HADENSMITH3534
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
Now that there IS an"OR" filter for view properties, how are things coming along with implementing that same functionality in Revit SCHEDULES?  I have a Revit project (.rvt) file that needs to be shared between 2 drawing packages, and that would REALLY help with constructing my List of Drawings (schedule)!
Message 17 of 55
Bump.............
Message 18 of 55
Look at post #4
Message 19 of 55
dnenovMXKU9
Bump - seriously, if it exists for View Filters ... 😕 🤔
Message 20 of 55
piotr_pikula_2
Bump, same as above. If we have it in stadard filtering then make it real also for schedules.
