Cut the roof
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
12965 Aufrufe, 7 Antworten
Cut the roof
Hi. I have created a roof by profile, but part of it enters the house. Is there a way to cut the roof that is entering the house?
7 ANTWORTEN 7
Nachricht 2 von 8
ennujozlagam
als Antwort auf: Anonymous
@Anonymous hello, post some screenshot for better understanding. thanks
Nachricht 3 von 8
Ilic.Andrej
Create "In-Place" family- create void extrusion and then cut the roof with that void.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 4 von 8
georgehobel
I just figured this out for myself a couple of weeks ago... so easy..
After you have created your roof, use the "vertical opening" tool to cut the section of the roof that you dont want .
First go to the "Architecture tab and find the "vertical opening" tool as shown in the photo above.
After clicking the tool, click on the roof that is creating the problem.
Now use the project browser to get to a view where you know the roof is causing the problem.  Most likely, a plan view.
Here's the catch... you wont neccessarily be able to see the problem roof as you go to sketch the void.  You have to know where to place the "void sketch" based on where you know the roof is protruding.
When you're done sketching, click the big green check mark, and the void you created will take the place of the roof that you were dealing with.
Love this tool...
"It's not the size of the dog in the fight, its the size of the fight in the dog....."
George Hobel
Reflections of Charlotte
Residential Building and Design
Nachricht 5 von 8
Sahay_R
Did you try to join your walls to the roof?
Rina Sahay
Revit Architecture Certified Professional
Nachricht 6 von 8
marek_obajtek
als Antwort auf: Ilic.Andrej
@Ilic.Andrej
Hey, how do you cut simple roof (not extruded one) with void? Each time it throws "nothing is there to be cut" message.
Nachricht 7 von 8
Ilic.Andrej
als Antwort auf: marek_obajtek
As far as I remember, it is impossible. Maybe that spot will be occupied with some timber that can just mask out the unwanted area...
Andrej Ilić
MSc Arch
Nachricht 8 von 8
Create the void in place and cut the roof while you are still in the model in place editing.  Then finish.
