- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
There is a lot on the topic of filled regions, but I have something happening that doesn't seem to be covered.
I have a filled region set to transparent. I am annotating in a host model and the building is linked in. For some reason the boundary lines only appear over certain portions of my linked file. As you can see from the screen shot I have attempted to illustrate the issue. On the left side the filled region is clear of the linked file and shows correctly, and on the right side it also appears correctly over the linked file. In the middle for the boundary lines are being obscured. This screen shot is with just the linked file and the filled region isolated, so there is nothing else to obscure the filled region.
I have a large project with many linked files and this is the only one that has this issue. It is not a view specific issue since I can drag the same filled region over the other linked files without any issue. Any ideas on why this is happening? Thanks in advance
