Revit Rendering in Cloud Missing Images Error
12 ANTWORTEN 12
Nachricht 1 von 13
1138 Aufrufe, 12 Antworten
Hey everyone,
I have material library and i can render easily in revit. But when i want to render in cloud an error exists.
Error says that : the following render appearance images are missing . Here is the screen shot. Can you help me ?
Thank you very much for your attention
12 ANTWORTEN 12
Nachricht 2 von 13
cbcarch
als Antwort auf: Anonymous
Nachricht 3 von 13
als Antwort auf: cbcarch
I cannot find the material library in my computer. Some say that check C:\Program Files\Common Files\Autodesk Shared\Materials, but the problem is i cannot find that materials folder. Materials folder does not exist in my computer. But when i check the control panel i saw that i have all material libraries. And i have materials in revit.
Nachricht 4 von 13
Viveka_CD
Hi @Anonymous
Can you make sure the rendering path is set correctly?
Add the path to the material's render appearance location in the Additional Render Appearance Paths (in Application Menu > Options > Rendering).
Let me know if this helps!
Nachricht 5 von 13
cbcarch
What version of Revit?
Try this location: C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\1
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 6 von 13
Revit student version 2018
There is no Materials folder :enttäuschtes_Gesicht:
Nachricht 7 von 13
als Antwort auf: Viveka_CD
I set my path but i think it did not worked
Nachricht 8 von 13
...and this additional render path contains the "Mat" folder that the error message is referencing?
Nachricht 9 von 13
als Antwort auf: barthbradley
Nop because i cannot find the "mat" folder
Nachricht 10 von 13
Can't find it? But, it must exist if you can Render locally. You can, right?
Nachricht 11 von 13
cbcarch
Try doing a "Repair" on the Revit installation.
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/FDS-Install/files/GUI...
Cliff B. Collins
Nachricht 12 von 13
Viveka_CD
Hi @Anonymous
Where are your texture files located locally? (on which drive/folder on you machine?)
As suggested by @barthbradley move this folder with the textures to the Render appearance folder.
Let me know if this helps.
Nachricht 13 von 13
I cannot find my texture files. I know that if i could find, i would move the folder but, i cannot find the folder. How could it be possible i do not understand really.
