Filled Region in Realistic Mode
Message 1 of 29
Does anyone know how to make filled regions match the rest of the drawing whilst the drawing is in realistic mode?
The RGB numbers are the same and the colours match in consistent colour mode. However once realistic colour mode is selected they filled region does not also change.
Replies (28)
Message 2 of 29
Filled regions are not 3d elements so I can see why their colors are different. You may want to use thin masses (no thickness) and assign materials to them.
Message 3 of 29
Alan.johnson1970
The realistic view must be applying shadows like in shaded view.
Where as consistent view has no shadows, and the filled region is not effected by the shadows.
AJ.
Message 4 of 29
Viveka_CD
Hi @Anonymous
Your drawing in Realistic mode is actually a render of the 3D model only showing the material finishes., whereas a filled region is a 2D tool that will not show up in realistic mode.
We have few users reports on similar issues in views whose visual style is Realistic, filled regions are displayed as solid black or solid white instead of the specified color and fill pattern. This has been resolved with the latest updates.
Please verify version of Revit are you using?
Message 5 of 29
I am using Revit 2017 version.
Message 6 of 29
Hi how to go about it ,
1-Make a copy of the section view toy are working on.
2- In the copied instance, put the display, on hidden lines ( adjust to the same scale as the copied from )
3- draw the filled region on the copied version
4- group select all by filter, then exclude the filled region you want to show. Now you should see only the filled region
5- place the hidden line view you've just created over the realistic view on  the sheet.
Now you have a realistic view showing the filled region detail.
@Viveka_CDwrote:
Hi @Anonymous
@Viveka_CDwrote:
Hi @Anonymous
Message 7 of 29
Did you ask the question?  It is not about how to show filled regions in realistic views, it is about their appearance in such views.
Message 8 of 29
In such a way, you will control the filled region appearance in the realist view.
Message 9 of 29
How?  The color of model elements depend on the lighting and shadow settings of the views.  Elements with the exact same properties can have completely different appearances in a Realistic view.  In what way would you control 2d filled region to match that?
Message 10 of 29
Because you can't control filled region in a realistic view ( appears in black or white) that is a fact.
however I mentioned clearly it's a way to go around it. Ok ?
thanks
Message 11 of 29
You didn't answer my question.
Message 12 of 29
I was referring to the elevation or section views in realistic mode not the 3D views for rendering purposes.
were you can superpose one over the other, two views to create the appearance of a filled hatched region within the realistic 2D section or elevation view. that way, you could show a filled region in the realistic 2D  mode if you need to.
Message 13 of 29
I know what you referring to. And I didn't mention anything about 3d views in any of my replies, because, obviously filled regions don't show in 3d views. But sections and elevations in realistic visual style are affected by lighting and shadow settings as well. That is the point.
Message 14 of 29
Never mentioned doing anything in the realistic view
Now did I ?!
Message 15 of 29
Now did you what? The entire convestion is about matching filled regions appearance (in a different non realistic view as your suggestion) with model elements appearance in a realidtic view.
I am not question your workflow ot technique. I am questioning the result.
Message 16 of 29
Yes, the results are as described above as well as the way to do it.
Message 17 of 29
Viveka_CD
Message 18 of 29
Afirmarive, I'm using Revit Version 2017
Message 19 of 29
jagostinho74
I am using 2018.3.1 and the filled region still shows as white solid when view is set to realistic.
Any workarounds for whis?
Assistant BIM/CAD Manager
Manchester, UK
Message 20 of 29
Viveka_CD
Hi @Anonymous
Can you please confirm if you have the latest updates for Revit 2017? (2017.2.3)
