filled region in project browser
NZhouSNYLF
NZhouSNYLF
some filled regions can be seen and selected in properties but not in project browser i.e. Families > Detail Items > Filled region, any reason or i simply missed something?
NZhouSNYLF
i noticed that the one not shown in PB don't have Identity Data, my guess is that one is upgraded from old version? how to fix it? i believe it's kind of bug and hope factory can look into it, i uploaded RVT FYI
RobDraw
I’m sure the factory has more important things to do. Why don’t you ask the users that ARE here to help?
Rob
How did you create that filled region type?
NZhouSNYLF
thanks Toan, i copied from old (template) file, if it cannot be fixed then recreating template file from scratch is needed.
The filled region type probably comes from an old legacy template when the access via the project browser function wasn't made available.  I would recreate the filled region type(s) from scratch or by duplicating from a 'normal' type.
NZhouSNYLF
right, that seems the way out, thanks again Toan
