Displaying a dynamo value on a sheet.
1 ANTWORT 1
Nachricht 1 von 2
smartplans
243 Aufrufe, 1 Antwort
I have created a Dynamo code that calculates the areas of windows, doors, floors and ceilings in my projects. It then works out the heat-loss through those elements and then compares the results with a control model of the same dimensions. The result is a that I have a number of values that I would like to display on a sheet. (Revit analysis doesn't work for me... far too complicated). I thought about setting the values to global parameters, but I'm having difficulty representing the Global parameter as a simple text label to display  on a "Results" sheet.
Any Ideas?
1 ANTWORT 1
Nachricht 2 von 2
L.Maas
als Antwort auf: smartplans
Add parameters to your sheet template and fill those with the value from Dynamo. Other option might be to create a generic annotation family with the required parameters. Place that family on one or more sheets and then use Dynamo to fill those values
Louis
Please mention Revit version, especially when uploading Revit files.
