Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Filled region area tag
yes_and_no
Message 1 of 10
yes_and_no
  • Can someone help teaching me how to step by step creating a filled region area-tag ? Thx.
Replies (9)
Message 2 of 10
Yien_Chao
you just need to create a shared parameter for filled region. only then you can create a tag.
Message 3 of 10
Are you meaning an Area Color Scheme?
Message 4 of 10
The Area parameter of a filled/masking region is not exposed to be tagged even though you can see the value in its properties.  There are many other elements can be tagged out of the box:  Areas, Rooms, Spaces, Zones, Pads, Floors, Ceilings, Roofs, Conceptual Mass...
If you insist on showing Area in a Detail Item tag, then you will need to learn Dynamo.
Message 5 of 10
yes_and_no
Nope, just tagging regular filled region for many reasons...
Message 6 of 10
yes_and_no
I hear you.
What if I step back the demand and use schedule instead, wd it be possible
Message 7 of 10
@yes_and_no wrote:
I hear you.
Same answer.  You will need to use Dynamo to pull the Area value.
Message 8 of 10
Rectangular-shaped?
In-Place or Loadable Filled Regions that are "stretchable" in the x and y direction.  x and y associated to a shared parameters. These same x and y shared parameters are loaded into tag family. Tag family uses Calculated Parameter to report Area from these 2 shared parameters.  x*y=Area.
Message 9 of 10
Here is an example of Dynamo driven Filled Region Area tag.
Message 10 of 10
yes_and_no
Unfortunately, they are not simple rectangles. Anyway, I made tag that
reports filled region with type-in area, not ideal, but ok. Still less work
than editing a floor or mass boundaries.
