- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Has this happened to anyone? A filled / masking region does not show up when dropped into a project plan view. But when I drop one into a virgin project with the same view template, it works perfectly.
Points that were checked -
1) Active and visible Workset
2) In View Template - Detail Items are turned on
3) No filters
4) Even switching/removing the template did not help
5) Visible lines were used to sketch the outline
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
