fill pattern wall
3 REPLIES 3
salmnmhdi
271 Views, 3 Replies
fill pattern wall
Regards
is there any way i can make the fill pattern in walls appears on a fine level and not only coarse ?
Thanks in advance !
Tags (1)
3 REPLIES 3
in reply to: salmnmhdi
View Graphic Override:
Parts:
Do you mean the Coarse scale fill pattern? If so, VG and set walls category's detail level from By view to Coarse.
handjonathan
Hi @salmnmhdi
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @barthbradley @ToanDN helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
