Hi guys
I have calculated the value of the cut for footings. Now I want to see the volume of backfill over the footings. How can I achieve this? I have calculated cut using Building pads and phases.
Are you 2 working together with @amarkonathala ? https://forums.autodesk.com/t5/revit-architecture-forum/excavation-volume/td-p/10605194
Anyways, you have 2 Options:
Option 1:
Option 2: Create a graph in Dynamo that gets the geometry of column and foundation, creates a solid from both, transforms toposurface to a thickened solid and splits both solids giving you the amount of backfil on top of the foundation less the columns...which is something similar to what @amarkonathala posted on the above link
I do but I am sorry I cannot help you with that
Do you need to show the actual backfilling in the model or do you just need to get the volume?
