- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Have a Revit central file from Revit 2013. When I try to open it an error message comes up and says "Can't make stair". Then it says "file load cancelled". I have tried opening the central file, detaching from central file, and audit along with both of those options. Nothing seems to work to open this file. In the error window it doesn't let me delete the stair which is causing the problem either. Not sure what else to try to get this file open. There are no backup files since this was a central file - and we don't have the same computers with the local files anymore.
