I have a problem that when I change any wall type or thickness the revit crash and submit a fatal error for me, can you please help me
Solved by L.Maas. Go to Solution.
Dear Ennujozlagam, I met all your points and I everything is perfect, did you open the file and tried to change wall thicknesses?
I had a look at your project. There are errors in the file. If I try to open it in Revit 2016 I get this message:
It is best to first secure (backup) the files you have now.
Then it is best to go back to one of your backup files. Otherwise do as the error message states. Open your project with "Audit" selected.
It is possible that you will loose some information/families because they became corrupt.
Louis
Please mention Revit version, especially when uploading Revit files.
