Dear friends
Hi
i got an issue with dimension line.
When i change the value of Line Weight and Tick Mark Line Weight in type dialog box of a dimension line it does not change the line weight in view. Why and how to do it ?
Regards
Deepak Gupta
architect
Dear friends
Hi
Regards
Deepak Gupta
architect
Solved by josemukalel. Go to Solution.
Make sure that you are Changing the same dimenion style,or Check the "Thin line" is on or off
Thanks, Thin line command was on.
I have got a few more queries ;
1. Is there any way to show the lines of core layer of a wall in thick lines and lines of finish layer in thin lines ?
2. When we dimension a wall, Revit by default picks the center line of the wall and we have to press tab to pick the interior/ exterior side of the wall.
Is there any way by which Revit picks the interior/ exterior side of the wall by default ?
Regards
Regards
Dear josemukalel
Thanks for the explanations.Excellent videos.
It solved my problem.
Regards
Dear josemukalel
Regards
