Fatal Error everytime
Hello, its my first time on this forum.
Don't know if I'm writting this to the good person but everytime i work with Revit 2017(after I opened a file) after sometimes I get a fatal error(It happen exactly 29 times to this moment) What can be the problem?
Thanks.
Thank you very much for your time .
The solution to the problem was the second solution.
Viveka_CD
Hi @Anonymous
Thanks for posting on our community! Glad to hear that your issue is resolved.
Can you let us know which of the following tests helped resolve this error? This will help others looking for similar solutions.
  1. See if the results are the same if you right-click on the Revit shortcut > Run as Administrator See if you can save when running the application this way.
  1. Can you save to a different location to avoid the crash?  For example, try browsing to the Windows Desktop and see if the crash persists.
  1. Verify if you have any antivirus software running which may be interfering with the Revit.exe process.  If so, test temporarily disabling the software to see if you can save normally with Revit.
Looking forward to your reply update.
