- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a project with around a hundred building components in which I need to store their XYZ positions in their instance parameters. Originally I used dimension lines that measured the distance between an “Insertion Point (Adaptive)” located at the project origin, and a “Shape Handle Point (Adaptive)” located at the intended position of each component instance.
Now I created a new version of these families which can store their angle (“Alpha”) values. The problem is that, when I try to update the families to this new one, the position of each component instance is reset, and the instances move from their intended positions (where the Shape Handle Point was located) to the project origin point (where their Insertion Point is), as shown in this video:
The “Pin (PN)” command, or creating dimension constraints, do not prevent this from happening, and I can’t manually correct the position of every component instance after updating its family, since I would need to repeat that process around a hundred times (the video shows a simplified file with only two components, for obtaining help easier).
Do you know how I could update the families while preserving the intended position of the component instances? In advance, thanks for your attention! Attached is the project file (2021 version) if useful.
