levels and heights
4 ANTWORTEN 4
Nachricht 1 von 5
htews
259 Aufrufe, 4 Antworten
levels and heights
can I change to level say 200' to a level of 100' WITHOUT changing the height (200') level?
4 ANTWORTEN 4
Nachricht 2 von 5
vitorbortoncello
als Antwort auf: htews
levels are defined by their elevation relative to a base point, so changing the level’s elevation also changes its height. To change a level from 200' to 100' without altering its height: Create a new level at 100', rename it as needed, and delete or hide the original level.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 5
Move the Level Type's Elevation Base (e.g. Project Base Point or Survey Point).
Nachricht 4 von 5
handjonathan
Hi @htews
Thanks a lot for posting your question to the forums!   Has the solution suggested by @vitorbortoncello @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 5 von 5
Turn on project base point and move it down 100'.
