Family types are not loading in the project
damian_anoep
damian_anoep
Hi everyone,
I have made a family of a door. The hinges, handles and frame needs to be available in a few material options. To solve this, i made a couple family types in this door family. The parameters and family types work fine within the family itself.
However, when i load this family in to my project, the different family types are not working. They are visible in the menu (in edit type) but when i choose a family type, it stays the same.
Does anyone know how to fix this?
Thanks!
Damian
Post your file so we can diagnose the problem without a bunch of follow-up questions and guesswork.
damian_anoep
damian_anoep
Hi @barthbradley, thanks for your response.
Attached you will find the family of the door. There are multiple family types named with some metals.
When I load it in to a project it stays the same.
Hopefully you could fix this.
Damian
ralphdenhaan
Set your material parameters to Type instead of Instance:
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
damian_anoep
Hi @ralphdenhaan,
Thanks for your solution, it worked!
