- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi - I am working on a TV family that can be inset into a wall if an instance parameter is checked - see attached. To do this, I have the void (locked to a moving reference plane) that cuts the host/wall, set to move outside of the host the the parameter is checked. I've done this before to get around Revit's limitations when it comes to the visibility of voids in families. The problem is that when I uncheck this once it's loaded in the family, Revit throws up an error telling me the family isn't cutting anything and basically forces you to cancel the action or delete the family. In this case, it's by design that the void isn't cutting anything. Any ideas how to get this to work correctly (other than having two separate families)?
Note: If you're testing this, use a 6" wall. This is for a situation where I have a lot of deep walls and need to inset the TVs, trying to avoid a lot of manual manipulation of the wall types/layers/etc.
