you mean there's no libraries shown in Option=>File Locations=>Places?
See if this helps Revit 2019 content Library
..maybe you mean that there is no families loaded in to Default Project Browser?
...maybe you mean that when you press Load Family (under Insert Tab) it fizzles out and does nothing? Or directs you nowhere?
...maybe it's a particular family you think you should have, but don't?
...maybe it's a dumb terminal and don't access the main brain?
...maybe it's System Families. not Loadable Families that are not installed?
....Maybe a reinstall in in order? If you have several versions installed, Autodesk recommends installing them in sequential order following a clean uninstall.
https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall
is this the first time you ever installed Revit, @Anonymous? What Version did you installed? Have you worked with other versions of Revit?
Totally expected! Whew! Wipe the sweat of you eyebrows and press the Load Family Button on the Insert Tab and Locate and select Family. You should be directed to the Main Library Folder containing all the goods. You may need to drill down into into a few folders, but the nice thing is that they are named right for easy navigation.
I gotta know. @Anonymous: how would you rate you experience level with Revit? That info helps me to help you.
It seems like you started project on wrong Project Template or started without any Project Template.
