Family issue
Family issue
Family issue
Hello everyone,
I'm using Revit only a short time. I need an help, please.
I have two problems:
1) in "ANB-RE-A-MODEL-200-00" I have loaded "ANB_PORTA_ANTA SINGOLA_INTERNO_3D" but it doesn't work (the chassis doesn't fit to the various wall thicknesses) - I don't understand why!
2) I need to model the roof of "ANB-RE-A-MODEL-200-00" with the "Profile.dwg" but I don't know what is the best way.
Can someone help me please?
I'm becoming crazy because I don't find a solution.
Thank you so much.
Antonio
PijPiwo
@1 - see picture
@2 - in dwg, I’m not sure what I’m looking at. Is it a roof overhang profile? If yes, try to create a fascia profile family with the profile to match cad file and apply to the roof edge in your revit project.
FYI, you don’t need to model in 1:1 scale. It will never gonna fit the sheet. Change the scale to the value you will be actually putting on the sheet when printing. It will be easier to see the annotation and other geometry as well.
josemukalel
There is not enough constrains and parameters in the door family.pls watch the screencast
Jose George
Architectural BIM/CAD Technician
[email protected]
+64 22513 0828
A KUDO is always welcomed; However, WHEN the above answer helps and/or clarifies your query; kindly mark it with ACCEPT AS SOLUTION
josemukalel
I add some constrains ,but before use please modify Width and Height as per your req
Jose George
[email protected]
+64 22513 0828
For the door, now it's clear.
Thank you so much.
Bye.
Antonio
I'm going to try for the roof.
Thanks.
Antonio
