How can I split a railing into three parts? What it says here: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
I don't know how to fix the warning
Isabel
Gelöst! Gehe zur Lösung
Gelöst von PijPiwo. Gehe zur Lösung
Can you upload your rail with the sketch of what you're trying to achieve?
It happens with all railings I create
Isabel
I thought you could post rvt file as well …anyway, what the error basically means is that the base and base offset settings for the baluster/post cannot be above top and top offset.
I had the same problem. Can you detail your solution?
I dont'have this problem with metric template and I'm using Revit 2017.
Andre
Can you show us the rail element dialogue? You are using "Rail 1" as your top host and have a -100 offset from that element. You also have a 100mm offset above the host so I assume your "Rail 1" is likely not 200mm + above the host which is causing the error. Balusters have a 0 height.
