- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
im from the Autocad and Inventor-Corner and new in Revit. I'm using the Familie-Editor to create a Library for my Company and i must say this Family-Editor is very complicatet when i draw or edit an object.
Revit is not bad, but there are some point, which are not so good in Revit.
why didn't Revit use the same Commands as in Autocad or Inventor and in the same sequence? The trim command is different from those in Autocad or Inventor, but it's one Company...
I also miss for excample the champfer or the round command (hope i name it correct, sorry im austrian ^_^).
and what's an absolute no go in Revit => THERE ARE NO LAYERS!!!!!
did you ever use Revit, export it to Autocad and edit it in Autocad. It's soooooo horrible without correct Layer 's.
sure there are some layers from export but the wrong one. I need Layers that i can define. I need Layer's with the company name in front on the Layername.
thx
Chris
