I am editing a family and need to add a parameter, however the added dimension doesn't show up. I remember there is a setting that can turn on/off the display of the dimensions, but can't recall where to locate it?
Solved by ToanDN. Go to Solution.
@hliS658H wrote:I am editing a family and need to add a parameter, however the added dimension doesn't show up. I remember there is a setting that can turn on/off the display of the dimensions, but can't recall where to locate it?
Huh? Do you mean you edited a family and added an length parameter - and that length parameter doesn't show up under the TYPE or INSTANCE Properties of the Family in the Project?
