Family: cant use both model text value parameter and dimention parameter
danezeq
Message 1 of 20
danezeq
I keep trying to build a sign family that display parametric text on both side of the sign
AND
Keeping that text vertically and horizontally centered.
I manged to do ONLY one of them each time. tried everything for almost 50 hours virtually without sleeping!
I tried change the parameters both instance and type, tried to use reference lines instead of planes..etc
Does anybody has a clue?
https://www.youtube.com/watch?v=vGcsU4lCZAw
Note: in this video i occasionally opening family type window and change type - in the purpose of check if the error appears.
Replies (19)
Message 2 of 20
martijn_pater
Try aligning and dimensioning to a reference plane instead of the model text directly. I can't seem to replicate the issue  here though, what happens if you use different text font? (not that I see how that would be related)
Message 3 of 20
danezeq
Here is the file
Message 4 of 20
danezeq
But then i should align the reference plane to the model text no?
Message 5 of 20
martijn_pater
You would align the text to the reference plane. Added an equality dimension to that, see attached.
Message 6 of 20
danezeq
The problem still there (in the attached file)
When i assign the back text parameter for the back text, i get the constrains not satisfaied error as soon as i change type.
https://www.youtube.com/watch?v=e1KQx0a8MEA
Message 7 of 20
martijn_pater
Try to (re-)align after you've associated the parameter.
Message 8 of 20
danezeq
i released the two locks of the back model text and re aligned it to the two reference lines (vertical and horizontal) , and lock it.  Again, some of the types give back this constraints not satisfied error.
Message 9 of 20
danezeq
Here is the exact way i ruined your file:
https://www.youtube.com/watch?v=TZMzr9V6XLM
Message 10 of 20
martijn_pater
I did manage to reconstruct the error earlier, it did seem to work after realigning though. Sorry, would have to look at it again, but can't right now, away from computer. It's a little difficult to deconstruct though, language wise, maybe i was missing something. Perhaps it would be better/easier to nest the model text as family...
Message 11 of 20
martijn_pater
Except for the "empty" text message for some text fields, the family should work. The difference was with the video you showed, is that I did not constrain the family horizontally. Just vertically with equality dimension. I don't think it's nescessary to constrain it horizontally, since your sign has equality dimensions to all sides, therefor always being in the middle. So if you have your text set to "center" this should always be centered anyway.
Message 12 of 20
RDAOU
@danezeq
Model the Text in a Generic Model >>  nest it into the Special Equipment Family >> lock it to the center of the plate. The equality measurement string needs to be anchored properly for it to behave centric. It is more or less similar to the single sided sign posted to your other question. See screencast below.
Note: Forum not allowing me to attach the .rfa (no attach button for some reason). If you want the .rfa, PM me your email and I will send it via wesendit.com
Message 13 of 20
martijn_pater
Yes, nesting it as family probably allows you to constrain it better, I think I might have mentioned doing that. Although with the family at hand I don't really see how it would not be properly centered as you say, as the sign itself is constrained horizontally and the text vertically to the sign itself. Once aligned (not locked) to the center that text is going to stay in position... unless I missed some horizontal offset parameter.
Message 14 of 20
danezeq
Okay for some reason it works well now. i didn't use @RDAOU 's method for now (actually i need to seat and go deep into that)
I HATE it when a problem which i had go away and disappear without me to learn something.
that is the case.
I really want to point the solution for archive purposes (for the next users who will search for the same issue) and it's frustrating that i cannot tell what exactly solve it.
few guesses:
1. didn't use reference LINES
2. i draw 4 reference lines, 2 for each view and didn't use the same reference line for both views.
Still, some other problems occur now like i get the same "constraints not satisfied" error when trying to change the text size (of the model text)
Message 15 of 20
martijn_pater
Ah ok you want to give it parametric height, didn't realise that before then it is better to nest the model text as family. The reason is that the text alignment changes in relation to the reference plane it is constrained to. (You can also draw an additional reference plane with parametric dimension to the equality reference plane, related to the text height parameter. correction, can't make that parametric unless nested = family loaded into other family) You can do that following the screencast by @RDAOU (who apparently uploads too many solutions and reached some sort of forum limit 😉 ) This way you can associate a height parameter from the nested/loaded family and constrain it to the center.
Constrain and alignment issueConstrain and alignment issue
Message 16 of 20
danezeq
Sorry for the embarrassing question: NESTING means a "family inside a family"?
after googling and youtubing "nesting" this is my only guess..
Message 17 of 20
RDAOU
@danezeq
Make the plate visible in elevation (front/back) and test it in a model.
Unsubscribing to this post...again if you need the file toss your email into my inbox I am still not getting the attach button when I reply to message!
Message 18 of 20
martijn_pater
No worries, a nested family is exactly that, a family loaded into another family. I´ve attached an example .rfa for the model text alignment and the parametric height.
edit: Just realized I used a face based family template for it. But you can also use generic model with workplane based selection box turned on as shown before. Both should work, constraining the model text works the same also.
Message 19 of 20
danezeq
Thank you @martijn_pater  and @RDAOU  for all your big help.
Message 20 of 20
AAlsarhanGL73L
Community Visitor
Community Visitor
can we have width parameter applied?
