Failed to print PDF Revit 2018
Message 1 of 37
My Revit 2018 will not print to pdf.
"Creating Adobe PDF" window opens and looks like it is starting to process the print but then it freezes and the PDF file is never created.
Accepted solutions (3)
Replies (36)
Message 21 of 37
georgehobel
I downloaded a different pdf creator than what I was using... have not had a single issue since...   Bullzip is what i am using now, works fast, and no hang ups... I dont have to jump through any special hoops.  Blue beam is another, but the price is high.. and the learning curve is steeper than learning revit.  I was using Adobe DC pro, but the Adobe just cant interface with Revit other than to view your pdf's.  Bullzip was no charge, and like I said.. no hang ups.
George Hobel
Reflections of Charlotte
Residential Building and Design
Message 22 of 37
ckhill
This issue is STILL present in Revit 2019, and I dont accept the solution that I have to install a new PDF creator in order to publish to PDF files.
Can someone at Autodesk please provide a reasonable solution that does not involve installing additional 3rd party software?  Better yet, can you please fix this issue that appears to have been present for several years.
Thank you,
Cathy Hill
Message 23 of 37
AFatRat
The solution is to do a print preview before you hit print. Yes, it's an extra 3 clicks. Not that hard.
I completely agree that this issue is ridiculous and needs to be addressed but you don't need to download anything.
By the way, there is no native pdf creator in revit. Whatever program you use to create PDF's is a 3rd party software.
Message 24 of 37
georgehobel
"I completely agree that this issue is ridiculous and needs to be addressed but you don't need to download anything.
By the way, there is no native pdf creator in revit. Whatever program you use to create PDF's is a 3rd party software".
just wondering how to balance these two statements....
George Hobel
Message 25 of 37
AFatRat
You know what I'm saying, boss. Adobe works. Just preview it first. No need to download anything else.
Are we balanced?
Message 26 of 37
georgehobel
LOL... yeah were good... but you gotta download adobe at some point.  I was using Adobe DC Pro, but it would hang up and cause fatal errors constantly... I tried all the special pathways that were listed on this forum, nothing worked... and...even when it did work, it took forever to actually plot the pdf... bullzip is quick, and I have had no issues.
George Hobel
Message 27 of 37
Viveka_CD
@georgehobel
There is a patch you can download from this thread for Adobe DC Pro to resolve the temporary freeze
(19.010.20098) is the patch version.
Let me know if this helps with your issue.
Message 28 of 37
AFatRat
Oh. I had not heard of it causing fatal errors. I wouldn't deal with that either. Everyone I've talked to in and outside my office has confirmed that doing a preview before printing alleviated the issue with Adobe PDF. To be honest I hate Acrobat and I think this problem is with Adobe's software, not Revit. I would much rather be working in bluebeam but we get Acrobat with our Adobe subscription. C'est la vie.
Also, are you the Black Dahlia killer?
Message 29 of 37
georgehobel
I will check that out... thank you
George Hobel
Message 30 of 37
AFatRat
No, that thread is dealing with a different issue but I tried the suggestions there to no avail. Also, the latest patch for Acrobat is actually 19.010.20100 which we have installed.
Message 31 of 37
robk
Who told you??
:0
Message 32 of 37
mark47
Community Visitor
Community Visitor
worked for me also. Very frustrating though
Message 33 of 37
fabrisiq_ez
None of the proposed solutions worked for me. After a long time of frustration, trial and error, I found that the following procedure works, if done just before printing:
1) Close Adobe Acrobat
2) Go to task manager (Ctrl+Alt+Delete) and terminate the following apps: Adobe Collaboration Suite, Acrotray & Acrobat Distiller - sometimes they will be each one on a line on their own, other times you will have to expand the Revit line to shown them.
Message 34 of 37
I just ran into this problem. The fix had noting to do with the PDF printing application. I had an invisible viewport in one of the sheets that always printed as a blank. Deleting the viewport solved the issue. No idea how that viewport got there. Left clicking and dragging the mouse outside the sheet boundaries can reveal if such a viewport exists.
Message 35 of 37
Uriga
Thank God. Hire this man, "King Workaround of Adobe".
Message 36 of 37
It isn't adobe fault because Revit doesnt work properly with other pdf creators either
Message 37 of 37
Uriga
No no, you are absolutely right.
