Failed installation Revit 2014 Windows 8, Result=1603, Result=1619
noeliajr
Observer Observer
noeliajr
Observer
Observer
I've been trying to install Revit 2014 or 2015 for more than a week, and everytime I've got the same problem,
2015/2/16:18:54:19 noelia NOELIA === Setup started on NOELIA by noelia ===
2015/2/16:18:54:19 noelia NOELIA Path_Length: 149
2015/2/16:18:54:19 noelia NOELIA Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2015/2/16:18:54:19 noelia NOELIA Launch
2015/2/16:18:54:19 noelia NOELIA CommandLine /url "http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US... /SN 900-50533222 /PK 829F1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2015/2/16:18:54:19 noelia NOELIA Setup Windows update reboot is pending
2015/2/16:18:54:28 noelia NOELIA Setup Autodesk Revit 2014 Will restart automatically.
2015/2/16:18:54:28 noelia NOELIA === Setup ended ===
2015/2/17:17:34:15 noelia NOELIA === Setup started on NOELIA by noelia ===
2015/2/17:17:34:15 noelia NOELIA Path_Length: 149
2015/2/17:17:34:15 noelia NOELIA Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2015/2/17:17:34:15 noelia NOELIA Launch
2015/2/17:17:34:15 noelia NOELIA CommandLine /url "http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US... /SN 900-50533222 /PK 829F1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2015/2/17:17:34:15 noelia NOELIA Current Directory C:\Temp\_AI4240.tmp
2015/2/17:17:37:41 noelia NOELIA === Setup ended ===
2015/2/17:17:34:19 noelia NOELIA === Setup started on NOELIA by noelia ===
2015/2/17:17:34:19 noelia NOELIA Path_Length: 149
2015/2/17:17:34:19 noelia NOELIA Current Directory C:\Temp\_AI4240.tmp
2015/2/17:17:34:19 noelia NOELIA Launch
2015/2/17:17:34:23 noelia NOELIA Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64....
2015/2/17:17:37:39 noelia NOELIA Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64....
2015/2/17:17:37:40 noelia NOELIA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Temp\_AI4240.tmp\Setup\RevitSetup.dll
2015/2/17:17:37:40 noelia NOELIA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/2/17:17:37:41 noelia NOELIA PageOpen LaunchDialog
2015/2/17:17:40:29 noelia NOELIA PageOpen LicenseDialog
2015/2/17:17:40:29 noelia NOELIA PageOpen ProductInfoDialog
2015/2/17:17:40:29 noelia NOELIA PageOpen ProductSelectionDialog2
2015/2/17:17:40:47 noelia NOELIA PageOpen FullProgressDialog
2015/2/17:17:40:48 noelia NOELIA Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.ta...
2015/2/17:17:41:05 noelia NOELIA Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.ta...
2015/2/17:17:41:05 noelia NOELIA Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2015/2/17:17:41:16 noelia NOELIA Install DirectX® Runtime Succeeded
2015/2/17:17:41:16 noelia NOELIA Download Play RVT2014 http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x6...
2015/2/17:18:26:29 noelia NOELIA Download Aborted RVT2014 http://edutrial.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x6...
2015/2/17:18:26:29 noelia NOELIA Install Autodesk® Revit® 2014 Failed Download Failed, Installation aborted, Result=1603
2015/2/17:18:26:32 noelia NOELIA Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
I don't know how to fix this, any help?
Mirko.Jurcevic
Your post should be transfered here:
http://forums.autodesk.com/t5/installation-licensing/bd-p/24
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
