PARAMETERS FOR ADDING DIMENSIONS AND GET PERIMETER OF A SWEEP
arq_rafael_p
arq_rafael_p
HELLO TO ALL THE COMMUNITY,
COULD SOMEONE HELP ME CREATE OR USE A PARAMETER THAT ALLOW ME TO ADD A SET OF SIZE OR CAN I GET THE TOTAL LENGTH OF A SWEEP FOR USE ON A TABLE
ARQ.RAFAEL.P
constantin.stroescu
You can do it as follows:
  • make a Furniture Family with Shared Parameters  (Length type of paramaeters)
  • load the Family it into the Project
  • in Project create a  Furniture Schedule.
  • in Furniture Schedule the Shared Parameters appear as Available Fields , so you can Add them to the Schedule
  • for Perimeter , make a Calculated Value using Formula
Constantin Stroescu
arq_rafael_p
Good answer. The listing obtension families.
I have a family site, which is prepared by a sweep and I need to get the sum of different dimensions attached image. as I can get the sum of dimensions of different families of this type.
atte. arq.rafael.p
constantin.stroescu
I've made two rough screencasts on this subject .
I used a Site Family as you did.
In my first screencast I used locked angles . In the second one parametric angles . Theese angles can appear too as field in the schedule ..
https://screencast.autodesk.com/Main/Details/c306d935-94db-4bec-b655-1149bc91980d
https://screencast.autodesk.com/Main/Details/e2c15989-e463-4a7d-b047-47d8b4d0f74e
Constantin Stroescu
