Fail to generate automatic landing layout
Message 1 of 18
Good afternoon
I am trying to create a straight stair with 12 risers + landing + 14 risers + landing + 12 risers, total 43 risers and I get this message: "Fail to generate automatic landing layout".
I was following this solution https://forums.autodesk.com/t5/revit-architecture-forum/stair-landing-problem-problem-and-workaround...
but it's no working.
any suggestions please? 🙂
Thank you
Pedro Ospina
Bachelor in Architecture - Naval Architecture Student
Golden Gate Network
Replies (17)
Message 2 of 18
Message 3 of 18
12+14+12+5=43
Message 4 of 18
What???
...yep. My Texas Instruments Calculator confirms it.  12+14+12=38.  Smiley Wink
Message 5 of 18
I am counting the 2 risers generated by the 2 landings=4 + the final landing at the end =1:
38+4+1=43
Message 6 of 18
See below:
Message 7 of 18
That's 12+14+12 plus another 5.  Where does the 5 risers come from?
Message 8 of 18
You don't count landings.
Message 9 of 18
5 = 43-12-14-12
Message 10 of 18
Rebar cover is not activated 😞 I went into the family editor to find it but nowhere...
I did not work.
thank you
Message 11 of 18
miscalculation. I thought that landings generated 2 more
thx
Message 12 of 18
Default stairs ends a run with a riser...so you don't have a riser for your landing, it is at the end of the run.
@barthbradley's riser count is correct... See pic...ignore riser height...
Message 13 of 18
Alright then. 5 risers could be another 2 1/2 feet of rise (figuring a 6 inch riser height). Maybe we should ask what the total rise is supposed to be -- instead of guessing.
Message 14 of 18
Oh...straight stairs...Still 38 Risers  12 + 14 + 12 = 38
Message 15 of 18
Screw it, @Anonymous. Like I said on your duplicate thread: Use a Ramp.
he, he.
Message 16 of 18
I did not work.
thank you
Rebar cover is a serious bizness
Message 17 of 18
are you making funny of me?.
it's not cool
thanks.
Message 18 of 18
Not at all, @Anonymous! I like you. Promise.
I'm just feeling a little giddy. Sorry.
