Facet-slat bulkhead
Facet-slat bulkhead
dn_setshogoe
Facet-slat bulkhead
dn_setshogoe
Hi everyone
I'm about to attempt modelling of this slat-faceted bulkhead (as seen in the picture below).
what is the smartest family to use that will give me easy flexibility if I need to make changes?
Origami inspired Wood Ceiling Assemble Studio
BIM.Consultant
How about using curtain system with mullions and empty panels? You'll need to have the surfaces modeled as mass. If you have skp or dwg files you can go to "Mass in-place" and import them, then finish the mass and create the curtain system picking those surfaces.
BIM Consultant
dn_setshogoe
Hey
I'll try the Mass modelling and curtain System - it'll be my first time lol
I'm assuming you'd want me to make the slats as mullions and then put them at a fixed spacing?
Let me know if I'm right.
Thanks!
BIM.Consultant
Yes definitely. For the mullions you can create a profile family with parameters so later you can freely adjust their geometry. Again, if you have the surface modeled on different software, you can bring it to Revit. There is no need to model it again within Revit.
BIM Consultant
dn_setshogoe
Yes, I dont have a Sketchup or DWG. so I'm modelling straight from Revit. But it's good to know that I that option
Your legit awesome man!
Thanks!
