Tagging a tekla structures ifc file
1 ANTWORT 1
Nachricht 1 von 2
Joris.vd.Meulen
498 Aufrufe, 1 Antwort
Hi guys,
I have a Tekla Structures IFC-file which I link in my revit file. Revit does its 'converting to .rvt' thingy and Revit shows the structural model.
However tagging elements is impossible, it simply doesn't highlight any of the objects from that file.
Did anybody encounter the same thing? And more important: how can I tag 'm ?
Cheers
Joris.
love python coding
1 ANTWORT 1
Nachricht 2 von 2
alan.quinn
als Antwort auf: Joris.vd.Meulen
I understand you cannot tag elements coming in from a Tekla IFC when linked into Revit. This is a current limitation that will require work from both Tekla development and ours. Our development team is aware of this and from reading the internal case (which I have attached to this) the required changes will be released in an upcoming version. No hard date was given, but I suspect it will be comer rather that later. In the meantime if you Open the IFC as opposed to Linking it you will be able to tag all elements.
I hope this helps and let me know if you have any follow up questions or comments.
Thanks for posting.
