Extrusion Material of Nested Family Not Showing in Host Family
christiaan7KUDX
Message 1 of 19
christiaan7KUDX
Only some extrusions in the nested family are not showing their material in their host family. Specifically, the front door panels of the nested cabinet family.
I have attached the host family, and the nested family of interest is ..-CSWK-TYP-BASE CABINET
Any assistance is appreciated.
Replies (18)
Message 2 of 19
Weird. I had to delete it entirely from the Parent Family and load it again into the Parent Family to get it to work.
...to be clear: I deleted it from the Project Browser.
Message 3 of 19
christiaan7KUDX
Okay, that makes sense. Good work-around, but I was hoping for a logical answer as to why this might be happening.
Message 4 of 19
It works normally here.
Message 5 of 19
Dunno.  Got corrupted I suppose.  It happens.  There were other errors upon opening. Maybe related.
Message 6 of 19
christiaan7KUDX
Looking at your image got me to figure it out. The front doors were painted in the nested family.
When more than 1 surface of the extrusion is painted, it changes to core visibility of the extrusion to that of the paint.
Message 7 of 19
Arrgh! I thought I checked that. Guess not.
BTW: you can Paint Surfaces with Parameters. Did you know that?
How to assign a parameter to a painted surface in a family » What Revit Wants (wrw.is)
Message 8 of 19
christiaan7KUDX
I sure do! not much use for us now that painting changes the core material of these extrusions, but good tip for anyone else.
Message 9 of 19
That's not true. Paint is surface only.
Message 10 of 19
christiaan7KUDX
That's typically how it is, BUT with a NESTED extrusion, as soon as I paint more than 2 of the 4 sides of the extrusion, the core of the extrusion (along with all sides faces) will show up as the painted material in the host family.
Message 11 of 19
You must be doing something wrong then.
Message 12 of 19
christiaan7KUDX
This is how I'm testing this. Looking at the section cut in the host family, the core material changes when you apply the paint in the nested family to 3 or 4 sides.
Message 13 of 19
Message 14 of 19
Message 15 of 19
christiaan7KUDX
Thanks for testing this as well. I believe if you now cut a section, it'll show the core to be the Paint Blue material. (if you've painted at least 3 sides)
Message 16 of 19
Message 17 of 19
These screenshots show that same EXTRUSION TEST Family being cut by a 3D Section Box.
Message 18 of 19
christiaan7KUDX
Interesting, I'm getting a different result when 3 sides are painted. With 2 sides painted I get the same result as you, but I can't confirm if you've painted 3 sides from your screenshots. (I'm using revit 2022)
Message 19 of 19
 5 sides are painted.
Here's another screenshot for you...
