hello, I'm using revit lt & I'm trying to extrude a 2D mullion ive imported from autocad, while I'm highlighting the lines to extrude not all are being highlighted as its telling me its to small for the screen, does this mean these lines cant be done?
Hi @Anonymous
If it's smaller than 2mm it isn't possible.
If it's bigger than that, you should be able to reconnect the lines with some extra lines.
If you have a closed profile and you accept this form, it will create a solid form of 250mm high. You can extend it for your needs.
