Extruding
Extruding
Extruding
I'm pretty new to Revit, and am having trouble working out how to create a raised portion of a floor (for example, a stage) and would appreciated osme help. I'm using Revit2016.
ennujozlagam
hi, can you post some portion of it, so we know what do you want to achieve? thanks
constantin.stroescu
it could be done in several ways:
  • make a new floor type over the existing one and join , align and lock them
  • make a cut into the exisiting floor - in Sketch Mode > Edit Boundary > daw in inside shape that will be a cut ito the floor. Replace the cuted floor area with another floor type with a bigger width
  • if the height is bigger and there is an empty space between , then use a floor for the stage and perimetral walls from main floor to stage floor attached to both of them
  • you can also, use a Component >Model in Place > Floor
Constantin Stroescu
chrisplyler
Example of Constantin's third description...
