Hello, I'd like to suggest creating another attachment tool that essentially extracts the outline of the attached wall, and freezes it, eliminating the need to keep attached surfaces.
Reason: When working on a complex model (continuously changing roof) that requires this workflow:
Proposed solution: Enable the user to keep the attachment outline and extract a shape from it, that maintains the top/bottom of wall condition - i.e. freeze the geometry.
Please contact me if you have any question.
Solved by Sahay_R. Go to Solution.
Post this in the Ideas forum.
https://forums.autodesk.com/t5/custom/page/page-id/Ideas-Page
@Anonymous
To sum it up, you want to have the option to keep the shape of a wall even if the shape defining targets are removed. Sounds like a good idea. I would vote for it.
