Why does Revit only have a decent alphabetical parameter ordering system working correctly and not numbers?..
once you try and re order parameters in families with numbers instead of names they only work correctly for 1 - 10 once you get to 11 it puts it in the wrong place after 1?.. I have to add in 150 parameters. 1 - 150 so i have to move them up with the arrow function. Even that is driving me mad because i have to keep clicking it, why cant you hold it down and make it keep moving?? Is there a way to get around this quicker?? help
kinda solved it by adding a system like a machine would understand - I.e 001 - 150 to get the order right
Hi.
Try to use three digit numbering to make life easy.. and after adding parameters keep sorting order but ascending or decending
cause it doesn't refresh automatically.
Cheer!
