Extra layer appears on Architectural columns
l3ehnam.b
Observer Observer
l3ehnam.b
Observer
Observer
Hi, I started troubleshooting a model that has structural columns that I replaced with architectural columns, But in the floor plans, it's starting to show extra layers of finishing?? on the newly placed columns.
the problem is that when I place an extra finishing wall layer on them, it shows both layers which are incorrect.
Any suggestions?
MostafaElashmawy
switch join order.
Mostafa Elashmawy
l3ehnam.b
Observer
Observer
there is no actual layer, the column itself hs no additional finishing. but when placed in the drawing, Revit  puts additional layer inside the columns.
MostafaElashmawy
Yes I know,
This layer is added because of the join between the wall and column.
click switch join order, then click on the column then click on the wall.
If it didn't work, use "unjoin"
Mostafa Elashmawy
l3ehnam.b
Observer
Observer
Yeap, It worked, Thanks!
