realistic view missing wall
9 ANTWORTEN 9
Nachricht 1 von 10
1009 Aufrufe, 9 Antworten
why in realistic view the wall is being invisible while in consistent colors is visible?11.PNG
9 ANTWORTEN 9
Nachricht 2 von 10
MostafaElashmawy
als Antwort auf: Anonymous
It seems that the appearance tab of the material of this wall is set to glass.
Mostafa Elashmawy
Nachricht 3 von 10
ennujozlagam
double check your wall materials. thanks
Nachricht 4 von 10
als Antwort auf: MostafaElashmawy
when I render the appearance of the material is in the way that it should be, the floors and columns are being visible. how to make them invisible?
Nachricht 5 von 10
martijn_pater
@AnonymousIt is probably the appearance asset for you material (glass/gas/clear ie.) which is set wrong for the material, like eng.mostafa2414 mentions above. Replacing it with a correct asset should resolve it.
If you want to hide columns/floors in the view, you could just uncheck these categories in Visibility Graphics (in/outside of template).
Nachricht 6 von 10
als Antwort auf: martijn_pater
this is the exterior layer of the wall, and underclass category, it is set as generic, not glass
Nachricht 7 von 10
ennujozlagam
you cannot hide them because there will be a gap if you hide your floors and columns, you can paint them with same materials of your wall. thanks
Nachricht 8 von 10
martijn_pater
@ennujozlagamGood point, I may have taken invisible to literal there :leicht_lächelndes_Gesicht: Not sure what you're showing then though.
Could you check transparency settings there and/or try replacing with another asset to see what happens and/or with different,similar material alltogether...
Nachricht 9 von 10
transparency setting is unchecked!!
I am talking of the wall layer which is on the contact with the exterior.
should I check even other layers of the wall?
Nachricht 10 von 10
What if you delete that 3d view and create a new one?
