Extensions for Revit 2016
mikeleinback
mikeleinback
After considerable searching, I am still unable to locate Extensions for Revit 2016.  When chasing thru the maze of my Adesk account, I finally reach a point stating that the page is no longer available.  Does this mean that the extensions are no longer available?
After seeing numerous postings on the forum and following the directions of each, I always come back to the missing page.
Help!
L.Maas
For me it is available in my account. I can download it from there.
If you do not have it available in your account you might try to create a support ticket in your account and ask if Autodesk can check.
Louis
Please mention Revit version, especially when uploading Revit files.
RDAOU
@mikeleinback Hello
It is listed in Account Management still where @L.Maas showed you...You might Need to try Clearing cash/Cookies/history and trying again or try another browser.
Below is a direct download link should the above attempts fail
http://download.autodesk.com/SWDLDDLM/Updates/RXE/REX_2016_Win_64bit_dlm.sfx.exe
Alessandra.G
Hi @mikeleinback,
Sorry about the inconvenience.
I checked your account and you have two accounts with the same e-mail address. Most probably, that is the reason why you have issues in your Autodesk Account.
I’ve opened a support case 12643061 on your behalf and will get back to you via email as soon as I have more information or a solution.
Alessandra G
mikeleinback
Thanks for your input. I've heard from Autodesk and they are working to
assist me in resolving the issue.
Mike Leinback
mikeleinback@gmail.com
903.360.5445
mikeleinback
Alessandra,
Thank you so much for your assistance.
Mike Leinback
903.360.5445
