exporting to IFC
exporting to IFC
exporting to IFC
When export to IFC no one of my 18 linked Revit files in the project shows up in IFC.
Did I miss something or it is just like that?
nmarcelis
Using the standard IFC Export, Revit will not include linked models. To export the full model: Open the current host model and use Save As to make a copy of it. In the copied file, select each link and choose to Bind it to the host model. Export the full RVT model. Revit will export linked models when the option is selected to export them as separate IFCs is chosen: In the IFC Export dialog, click Modify Setup... In the General Tab, check the box for "Export linked files as separate IFCs." If you wish to generate one IFC file with all linked data included, you might want to use another software to link/append the separate IFC files and export it again to IFC - i.e.: you can use Navisworks to append all IFC files and iConstruct for Navisworks to export the appended files into one IFC model. Please accept this as a solution if this helped you
Revit Certified Professional Architecture, Structure and MEP.
