PostProcess Multiple Cloud Renders Simultaneously
ebroberg
ebroberg
I have a sequence of renders in the cloud and would like to apply the same post-processing effects to each render. I assume this is possible, but I can't figure it out. Any help would be appreciated.
L.Maas
That is not possible. As soon as you select multiple images those functions disappear. You might want to check/post something the rendering ideas section. You also could download the images and do the post-processing in a graphics program.
Louis
Please mention Revit version, especially when uploading Revit files.
ebroberg
Thanks for your reply. This is unfortunate. I will check into the Revit API and see if there is a way to access Revit cloud services to see if there is a customizable solution with coding. I want to avoid exported and editing individually.
Thank you.
