Missing Wall
Missing Wall
Missing Wall
How is it that this wall has disappeared in plan? As seen in the screen shot, I am able to see the window in 3D and not in the Third Floor Plan.
The wall was there a moment ago. It exists in the view range of the plan. It is not hidden. The doors show up and the wall does not. The construction phase is the same as the other walls. VG does not have a known setting for turning this wall type off, as it is a wall type that can be seen elsewhere on the plan.
RevitRx
workset issue? view filters? phasing?
www.RevitRx.com
A 'plan region' was touching the bottom right corner...
