Exporting to DWG excluding hidden lines
jessies2JUUJ
jessies2JUUJ
I've been trying to export a perspective view to a DWG but I cannot figure out how to configure the settings such that the hidden lines (for example the window frame within the wall) does not show up. Whenever I try to export to DWG the perspective is very messy because it includes all of these hidden lines. I have the transparency on the view set to 0, but what else can I do?
- If you want 3D DWG then export normally and change the visual style to Hidden lines or whatever you line in AutoCAD.
- If you want to export a 2D DWG snapshot of a 3D view, then place the 3D view with Hidden lines visual style on a sheet and export the sheet to DWG.
jessies2JUUJ
I do want to export a 2D DWG snapshot, thank you
- Create a sheet
- Place the 3d view on sheet
- Export > CAD formats > DWG
- DO NOT check this box:
2D DWG
