Exporting schedule to excel using DBLINK
Message 1 of 16
I'm trying to export schedule to excel using DBLINK but the tabs under MS Access 2007 and 2000-2003 are empty. Only ODBC able to selection connection.
Pls advise as I am using Microsoft Excel to edit scedule and then link back to Revit 2017.
Title edit for clarity: Exporting schedule to excel using DBLINK
Accepted solutions (3)
Replies (15)
Message 2 of 16
If I remember correctly you need Excel 2010 64 bit as the minimum. That was with the last time I used dblink in Revit 2015.
By the way, you don't export just schedules via dblink, but the entire model data. If you only look for a two way export edit import schedules, I would look into Dynamo.
Message 3 of 16
Thanks Toan for the info.
I definitely wont need to export entire project data, only one schedule but I am not familiar with Dynamo, dont know which boxes required to link to....sigh.
I'm using Microsoft Offcie 2016, but I cant select connection to export, not to talk about import.
Any solution?
Message 4 of 16
Is it 64-bit version?
Message 5 of 16
yes 64
Message 6 of 16
Not sure what else to suggest.  I have Access 2010 64-bit and DB Link with the option of export to MS Access 2007 works in Revit 2015-2017.
Message 7 of 16
I'm using Excel, not Access, that's the problem
Message 8 of 16
Magnus.B
I'm having the same problem, the MS Access tabs are empty. Do I need to set up a ODBC first? I'm running Revit 2017 and Access 2016.
2017-04-05 07_29_29-Autodesk Revit 2017.1 - [Sheet_ Startvy - WSP - Project1].png
Message 9 of 16
@Anonymous Why don't you use BIM Link in you need to use excel?
Message 10 of 16
Viveka_CD
Hi @Magnus.B
Please see the articles below:
Forum post HERE
Let me know if this helps!
Message 11 of 16
Viveka_CD
Message 12 of 16
Viveka_CD
Hi @Anonymous, @Magnus.B
Just checking in to see if you resolved the issue or you seek more assistance from the community.
Let me know and I look forward to your reply.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
Message 13 of 16
Magnus.B
@Viveka_CD Hi thanks for following up, my organization refuses to use office x64. and as of my understanding Revit 64 bit cannot talk to x86 Access.
Message 14 of 16
Viveka_CD
Hi @Magnus.B
Yes, looks like it.
If Access 2007 x86 is installed on x64 machine, the driver cannot be installed.
Refer to the table HERE for more information.
Message 15 of 16
Viveka_CD
For now, I have marked solutions to few workarounds to benefit the community!
If you have additional questions, we can continue this thread.
Message 16 of 16
gmansfield
Hi, i may have missed it but i dont see a solution for the original question. So maybe this will help as i experienced this today. I have ticked all the boxes;
Access x64 (doesnt matter if you install from 0ffice 365 or access standalone.)
All i did was download and install the AccessDatabaseEngine_X64.exe (https://download.microsoft.com/download/2/4/3/24375141-E08D-4803-AB0E-10F2E3A07AAA/AccessDatabaseEng...)
And it gave me the the [Select a new connection] from the MS Access 2007] tab.
GARY MANSFIELD | bim manager
ckr consulting engineers
johannesburg
south africa
