Exporting Revit to DWG, 3 KB Only
Message 1 of 8
The DWG file exported in Revit 2019 is only 3 KB in size regardless of the explixity of the model, either a box or an office tower, and it is not a valid DWG file.  I have no such issue with previous versions and my colleagues had no trouble exporting in their pcs.
I have tried repairing the program and reinstalling the program.
Revit version:
19.2.10.7
20190225_1515(x64)
2019.2.1
Replies (7)
Message 2 of 8
Modify DWG/DXF Export Setup?
Message 3 of 8
Thanks for your reply.
Normally I just use the default setting, except using ACIS for solids, same as how I do with previous versions.  It should export to a valid DWG file regardless of the settings.
Message 4 of 8
Let me try. Post the File.
Nevermind. You say it happens with the simplest geometry?  Yeah, that would be a local issue/setting.
@Anonymous : This may be related:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Message 5 of 8
Yes, it is a local setting in my PC: "Region Settings"  I checked "Beta: Use Unicode UTF-8 for worldwide language support".  Once I check it off, Revit exports properly.
Thanks!
Message 6 of 8
Give yourself a cigar!  Mark your post as Accepted Solution. Good info to be shared.
Message 7 of 8
Thanks!
Message 8 of 8
zz1zz2zz3
Observer
Observer
I had the same problem. So i reinstalling RV but not changed. Almost file and mode and sheet export to dwg not open with autocad apply. And file only 3KB. So I worry? I found info this subject on other forums but not find best reply. I think Autodesk can not support?
