Exporting PDFs with images in schedules
- Mute
- Permalink
- Report
Has anyone found a workaround to this?
When exporting a PDF containing a schedule that contains images, if the schedule has been formatted to display a background on the cells the images won't print.
Schedule with Images display correctly on the screen when exported, no images are visible in the cells with background.
Currently using Revit 2024, schedules with images as a parameter. Settings on the schedule are show Stripe Rows (Appearance).
Currently Autodesk reports that the issue is known, but they say it can be fixed by printing instead of exporting. It does not work. Incident 202284
Image attached. On the left as seen on the sheet in Revit, on the right exported PDF.
Top schedule doesn't have a background nor striped rows, bottom schedule has striped rows.
