I wanted to export a sheet as PDF from Revit 2024.2 and I am getting a yellow colour in the PDF that non existing in the active sheet view in Revit.
Revit Sheet View:
Exported PDF view:
I am expecting Revit should export it as is but there is a yellow colour in the PDF. I am aware that I can export a grayscale or black line version of it, but I have never experienced a discrepancy like this.
I have linked architectural Revit model within my structural model and I set it to host view from display settings.
I am using this Revit link as underlay with no overrides.
Is there a way to export PDF exactly like in the Revit active sheet view?
I am using Revit built in pdf exporter with following settings:
I have other linked views that can be exported as is without colour discrepancies in the same project.
Kindly provide input if possible.
Solved by vitorbortoncello. Go to Solution.
