Exporting from Archicad to Revit
JDangondKGLDX
JDangondKGLDX
Hi all, im having problems exporting from Archicad to revit. I'm a revit user and tried to classify everything on Archicad and all the walls are showing as walls in revit but are not editable. Do you know how to join them?
Note: The way i'm using is exporting an IFC from Archicad and then Bind it into a new revit model.
nmarcelis
hi @JDangondKGLDX
Conversion problems are expected while working with ifc in Revit.
In archicad set the geometry to BREP in the IFC Translators (File Menu > Interoperability > IFC > IFC Translators) click the three dots next to Geometry Conversion and set the Export all model elements geometry as BREP as shown in the attached screenshot. Export a new IFC and the walls will retain their Trim/Crop/SEO.
Please mark this solution as the answer if this helped you.
Revit Certified Professional Architecture, Structure and MEP.
