Exporting floor plans and elevations as PDF file
Message 1 of 13
Please explain in steps as 1, 2 ,3 how can I export and save current views of floor plans and elevations to be able to save as PDF and JPG files in order to share when needed. Because all I could find Is how to export CAD format files.
Thank you !
Replies (12)
Message 2 of 13
aleksandr.b
To export PDF you should print view or sheet by virtual printer like PDFCreator, Adobe Pro:
To export jpeg do this:
Best regards, Aleksandr Barsukov.
Message 3 of 13
s.borello
Use print to create PDF's of your Revit views.
Message 4 of 13
Sorry, nothing happened. No window opens where I can choose where to save my image (current view)
Also it is JPG only option. I need to know how can I save it as PDF too.
Message 5 of 13
aleksandr.b
Did you follow gif that I posted above?
Message 6 of 13
I got it. But I also need PDF format. How can I save it or print to PDF ?
Message 7 of 13
aleksandr.b
Oops, gif with "how to print pdf" didn't post properly. Try this:
Message 8 of 13
martijn_pater
Sceenshot, save as jpg... (semi-)joking, see above answers 😉
Message 9 of 13
NOT working at all when I tried many times ! I did it all in steps you showed but I am getting empty file PDF with setting ''fit to page'' and corner visible only with setting ''100% zoom size'' and sometimes ''Nothing to see here". Also it asks "do you want to replace current file ?'' If I say YES it replace it with empty or corner visible and if I say NO it does nothing. So if I want not to replace file but create new one how can I do that ? What am I doing wrong here ?
Message 10 of 13
Message 11 of 13
aleksandr.b
mb post your file here to understand problem
Message 12 of 13
I do not know how to do screen share so you could see what is on my screen ?
Maybe I should change something with size where it says ''letter, A4, A5'' ?
Message 13 of 13
aleksandr.b
yeh, you should set true sheet format
