Export to PDF artifacts appearing in sheet Title
stingers80-cgarchitect
I'm trying to use new Export to PDF command but view titles get this sort of artifacts. Is this a known issue?
this is my Export setting:
syman2000
Can you upload the sample view title and see if user can replicate your issue? I seen these issue when we had windows update that affect Adobe, Bluebeam and other PDF export. Once you install windows latest update, it solved these PDF issues.
Here's the Family.
As far as I know i'm on have latest Windows updates. No problem with other PDF printers.
syman2000
Looks like the view title parameter is mess up. Whenever I put it Level 1, the number 1 will go to the next line and create those weird artifacts. I delete it and recreate it and that fix the issue.
thanks. recreating View Name Label solved it.
